Partitioned Pie Chart available?
Yokai-FTW February 4, 2023
I'm fairly new to Jira so spending a lot of time googling for answers. I'm not sure how to phrase a search for what I want, so here I am!
I have 3 different Epic types that are differentiated by labels.  We'll call them "plan", "do it", and "verify" that each have various tasks in them. I have a filter that returns all the tasks from these epics and displays them sorted by status.
What I'd prefer is the chart to be segmented by Epic type, and then display the count by status for the tasks in each Epic.  I could get the same effect with 3 separate charts of course but prefer to have it in a single chart. (In Excel, it would be sort by "type", and then sort by "status". if that helps clarify.)
Thanks for any suggestions!
Carlos Garcia Navarro
Hi @Yokai-FTW ,
If I understood correctly, you could search the issues under an epic type using a filter or JQL query as described here: https://community.atlassian.com/t5/Jira-questions/Getting-stories-related-to-all-any-epic-with-specific-label/qaq-p/1108374
And then, add a pie chart gadget with the statistic type 'status'. Would that work?
Almost.  That's what I currently have.  It's like a typical pie chart.  What I'd like is more nested.  Something like this:
The inner ring has the browser and the outer ring has the percentages of revisions used.
That example is inside out of what I was thinking with an outer ring of the number of each type of Epic, and the inner ring having the count the tickets of each status.
