Pending Status
Liz Goodwill March 29, 2018
How can I add more "Pending Reasons".
What setting should I configure?
Aldis Kešāns
December 29, 2020
Open Custom Fields. Find Pending reason. Click on 3 dots un select "Contexts and default value".  And there under "Default Configuration Scheme for Pending reason" You will be able to add more pending reasons.
Michaël Monserrat
The values are in a custom field called : Pending reason
Nic Brough -Adaptavist-
March 29, 2018
You are going to need to give us more context.  Jira field options?  Status?  Post it notes in your house?
pending.PNG Too few options when a ticket is pending.  I need to add more reasons such as: waiting on user etc
Matthew Pantel
February 20, 2019 edited
If I am understanding properly, there should be a default status for waiting for customer already created within the Jira Settings screen. So instead of using Pending, use Waiting on customer. You can also edit these issue statuses to customize them for your organization, but if I am misunderstanding, please disregard lolwaiting for customer.PNG
Kian Stack Mumo Systems
March 29, 2018
Hey Liz,
If you are referring to adding more statuses to JIRA, you need to modify the statuses and the workflows. It's not clear to me if you are using Cloud or server.
Here is some documentation that may be able to help https://confluence.atlassian.com/jirasoftwareserver/workflows-939938674.html
 I am using the Cloud
pending.PNG There are too few of them.  I need to add more
