People Tab in the Project Menu
DeepakBhatia
In the peoples tab in the Project Browser Menu, gives an option of adding the user. But not remove a user.
How can we remove the user in the People Tab in the Project Menu ?
Regards
Deepak Bhatia
Ivar
January 16, 2012
You're on Jira 4.4? In the People view, select the "edit pencil" in the project role where you want to remove the user from. This changes the context of the page. When you get the possibility to search for users you will also see the uses already within the project role as a tag "User Name X". Press the "X" and select "Update". This will remove the user from the list.
DeepakBhatia
I am using JIRA 4.3.4 and I am not seeing edit pencil.
Regards
Deepak Bhatia
Ivar
January 16, 2012
Jira 4.3.4 does not have a peoples tab in the project browser menu? Do you mean Project Roles under Administration > Projects > Choose Project? Go to the Project Role and remove the users from there.
DeepakBhatia
Actually I am not able to attach the screen shot.
But I am talking about the Project Browser which has many options like
1. Summary
2. Issues
3. Road Map
4. People
5. Change Log
Ivar
January 25, 2012
Mine is Summary, Issues, Road Map, Agile, Change Log... But I am using Greenhopper. I guess you aren't :|
DeepakBhatia
We are not using the Green Hopper..............
Markus Lepper
January 15, 2012
Just open the list of users. Check rightmost option in the "Operations" column, which is "Delete".
BR, Markus
DeepakBhatia
Hi Markus,
Thanks for your response. Actually I am facing issue in the Project Browser, where People Tab in that particular project.
Regards
Deepak Bhatia
Markus Lepper
January 16, 2012
OK, Now I got it ;-)
Please see Ivar's comment below for the answer to your question.
Regards, Markus
Register today
