×I want to create a new People field to capture a user field in a form (different to the submitter, assigned or watcher), but when I create this field it doesn't appear as an option in the menu on the right hand side.
Custom fields of other types appear fine - it's specifically only the People type and doesn't work regardless of single or multiple selection.
You must add the field to the screen.
afterwards you should be able to add to the form as desired.
This is a Business Project so doesn't have the screens option under the project settings, and seems specific to the People field type only.
Steps to reproduce
ok so this must be a Team Managed Project since Company Managed business projects do have Screens. Now I do not do much with TMP actually. I don't understand step 4 - Create form for entry. Can you explain so I might assess?
By the way, I did a quick test in a TMP project, although it was software project, and added a people field. When I go to create an issue in the project the field does present itself.
Yes it's a Team Managed Project
Step 4
Oh, I see you are using the new Forms feature that was just introduced. To be clear when you add a field to an issue type it is not automatically available to any form that you might be building. In fact I'm not even sure if the People field type can be leveraged here. However, I'm not absolutely sure as I don't use TMP very much and I have used forms within TMP for sure. Here is some documentation you might wish to read please take note especially to section on Jira custom fields that are supported in forms. Please note that this document seems centered more around CMP. I have not yet found the associated TMP documentation.
I will try to find out more information on this and get back to you if I am successful.
Ok well thanks to @Mikael Sandberg for straightening me out. I had forgotten that JWM projects add a separate Forms feature vs. Proforma Forms whis actually is only currently in JSM. ugh...so confusing.
In any event Mikael indicated that he could replicate the same thing as you have seen @Niels Kee . So this is either a limitation of the forms feature or a bug. Based on the documentation link that I sent, which I believe is accurate, I expect this is a limitation. I might suggest that you reach out to Atlassian support for an official answer.
What you see looks to be a bug/limitation in the Form in a team-managed project that it cannot display people fields in the form. It looks like this can be related to this suggestion in JAC, JWMCLOUD-192.
I would recommend that you use the Product feedback option on the left-hand side. The JWM product team is really good at getting back to you.
Also have this problem now - was there any resolution earlier in the year?
I'm also running into this same limitation – is there any update on this or any news of when support for this will get added to JWM?
Yeah, I think I'll also need to go down another path while they improve the features in Jira Forms.
Thanks anyway!
Hi! Was this ever resolved? Asking because I am running into the same limitation issue.
I didn't see any resolution while I was hitting this problem and didn't get much guidance from formal support, so instead had to solve my problem another way
