Hi all! Had some reports of slow page loads, and, sure enough, scanning the tomcat access log shows several entries across the day like the following:
URL Response Code Bytes Sent Time GET /jira/s/d41d8cd98f00b204e9800998ecf8427e/en_AUnqmflm-1988229788/6159/7/09d7cf904052d036ab09c7074fd2e10e/_/download/contextbatch/css/greenhopper-rapid-non-gadget,atl.general,jira.global,gh-rapid-config/batch.css HTTP/1.1 200 72552 172219 GET /jira/s/d41d8cd98f00b204e9800998ecf8427e/en_AUnqmflm-1988229788/6159/7/09d7cf904052d036ab09c7074fd2e10e/_/download/contextbatch/css/gh-rapid-config,greenhopper-rapid-non-gadget,atl.general,jira.global/batch.css HTTP/1.1 200 71753 162733 GET /jira/s/d41d8cd98f00b204e9800998ecf8427e/en_AUnqmflm-1988229788/6159/7/81e09bd7dab1aeeee1270f7f3bb998eb/_/download/contextbatch/css/jira.admin.conf,jira.admin,jira.global,atl.admin/batch.css HTTP/1.1 200 67087 154605 GET /jira/s/d41d8cd98f00b204e9800998ecf8427e/en_AUnqmflm-1988229788/6159/7/81e09bd7dab1aeeee1270f7f3bb998eb/_/download/contextbatch/css/jira.admin.conf/batch.css HTTP/1.1 200 55572 142327 GET /jira/s/d41d8cd98f00b204e9800998ecf8427e/en_AUnqmflm-1988229788/6159/7/8416bb3c6914b4fee5f793acda2e8edd/_/download/contextbatch/css/greenhopper-rapid-non-gadget,atl.general,jira.global/batch.css HTTP/1.1 200 48925 133934 GET /jira/s/d41d8cd98f00b204e9800998ecf8427e/en_AUnqmflm-1988229788/6159/7/d3ab3c91dd139ba82a2d1dddec04d264/_/download/contextbatch/css/jira.global/batch.css HTTP/1.1 200 38563 116336
As you can see above (sorry about the mangled formatting mess), these requests are taking from 48 seconds to ~3 minutes to deliver. Any ideas as to what could be causing these slow loading entries? All of the real slow ones seem to be from the batch css, and I'm not too sure what is going on.
The bulk of the batch CSS request has been responded to in normal times (~100ms). I've had a look for services being kicked off by Quartz which could slow everything down, but cannot find anything.
Thanks for any assistance!
Take a few thread dump when system goes slow, probably you see bunch of
at org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRuntime.java:1741) at org.mozilla.javascript.ScriptRuntime.getNameFunctionAndThis(ScriptRuntime.java:2188) at org.mozilla.javascript.optimizer.OptRuntime.callName(OptRuntime.java:61) at org.mozilla.javascript.gen.less_concat_js_2._c_anonymous_41(less-concat.js:764) at org.mozilla.javascript.gen.less_concat_js_2.call(less-concat.js) at org.mozilla.javascript.ScriptRuntime.applyOrCall(ScriptRuntime.java:2430) at org.mozilla.javascript.BaseFunction.execIdCall(BaseFunction.java:269) at org.mozilla.javascript.IdFunctionObject.call(IdFunctionObject.java:97) at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:32) at org.mozilla.javascript.gen.less_concat_js_2._c_$_18(less-concat.js:261) at org.mozilla.javascript.gen.less_concat_js_2.call(less-concat.js) at org.mozilla.javascript.optimizer.OptRuntime.callName(OptRuntime.java:63) at org.mozilla.javascript.gen.less_concat_js_2._c_anonymous_55(less-concat.js:1115) at org.mozilla.javascript.gen.less_concat_js_2.call(less-concat.js) at org.mozilla.javascript.ScriptRuntime.applyOrCall(ScriptRuntime.java:2430) at org.mozilla.javascript.BaseFunction.execIdCall(BaseFunction.java:269) at org.mozilla.javascript.IdFunctionObject.call(IdFunctionObject.java:97) at org.mozilla.javascript.optimizer.OptRuntime.call1(OptRuntime.java:32)
on locked threads. If it is, then visit the issue (https://jira.atlassian.com/browse/JRA-37337) , and vote it :)
Just a shot in the dark, but are you using scripted fields?
Cheers
Hi Christian,
Yes, scripted fields are in use. Do you think this is connected somehow?
Hey, maybe. Depends on the fields :-) If you have very complex scripts that possibly scan through all of the existing issues it will definitley slow down your system...
I have a customer with the same problem, they have EazyBI and JIRA Agile installed. I have installed JIRA Agile elsewhere but have not seen this issue.
Hi Ben, if you haven't already, recommending checking Tansu's answer below - I believe this is the problem we were experiencing.
Hey Daniel,
I am running EasyBI and Agile,
We have apache redirect rule for the port forwarding. I disabled gzip on apache, but hasn't changed much.
Hey Ben, can I ask if you are running any or all of the following plugins? ScriptRunner, Behaviours, EazyBI or JIRA Agile.
It might be nothing, but some commonalities here might give me good reason to take a closer look at these plugins.
This is affecting our jira server too. We have 1,202,771ms and 1,085,499 meantime loading these files using JavaMelody 1.50.0. Would be good to have a answer.
I'm hoping that someone will have seen this before and know of the issue - am not expecting anyone to run through a logical analysis of the cause based on the very limited information above.
Help us plant more trees
