Sign up Log in
Permission scheme for custom issue type
Vishu Choudhary December 9, 2021
I have created some custom issue types Test Cases, Business Requirements, Other Requirements, and want to restrict the actions based on the issue types. Foe example: only testers in a group "Testers" can create the Test Cases issue type. Only BA/PO can create Business Requirements,... How can we achieve this in Jira. I couldn't find a place to control the permission scheme for custom issue types.
Sebastian Krzewiński
December 9, 2021
Hi @Vishu Choudhary
You can't do this based on project permission scheme because permission scheme set permissions for whole project.
You can achieve this by using custom validators provided by apps (eg. Script runner, JMWE)
Seba
Thanks for the response Seba. Do you know how can it be done via Script runner?
December 9, 2021
Hi
This code I used in workflow which is shared with many issue types in project:
def groupManager = ComponentAccessor.getGroupManager()
if (issue.issueType.name =='<Issue type name>') {
if (groupManager.isUserInGroup(issue.reporter?.name, '<Group name>')) {
return true
} else return false
} else return true
Vishu Choudhary December 14, 2021 edited
I'm getting multiple errors while applying the above code. One of them is attached.
Basically, I want to restrict the access for BA (under BA Test group) for creating/viewing the Business Requirement issue type (custom issue type).
Please advise.
December 15, 2021
1. You need to replace whole <Issue type name>. Is should be 'Business Requirements'
2. Group should be:
if (groupManager.isUserInGroup(issue.reporter?.name, 'Ba test group')
Vishu Choudhary December 15, 2021
Tried the above code and got two more errors. Sorry, I'm new to scripting in ScriptRunner.
December 16, 2021
Hi
What is the 'ba' variable in line 6? Where do you declare it?
Error from line 5 - where you put this code? Script console, validator, console?
Vishu Choudhary December 16, 2021
ba is the username of the user who is in group "BA Test group".
I have a bit of a change in the original requirement. Now I want to restrict the access based on the group. For example: only the users who are in "BA Test group" should be allowed to create the Issue Type "Business Requirements". I have different workflows based on different custom issue types. So, I want to add this script in the create part of the workflow and then adding a Validator.
Currently, I have tried running this script in ScriptRunner console but it should be run in Validator of the workflow, right?
Please advise the script for the above. Thanks :)
December 27, 2021
To test it in Script console you need to define issue and put user in ''.
Script should look like this:
def issue = ComponentAccessor.getIssueManager().getIssueObject('issueKey')
if (issue.issueType.name =='Prośba o usługę') {
if (groupManager.isUserInGroup(ba', 'BA Test group')) {
return true
} else return false
} else return true
Register Now
Upcoming Jira Events
