×Hi,
I'm working on a plugin that i need to save data from jira projects in seperate databases.
For this, i'm using the orm Active Objects and PostgresSQL like a database.
Error occurs when building the entityManager :
EntityManagerBuilder.url("jdbc:postgresql://localhost:5433/postgres").username(database.getUsername()).password(database.getPassword()).schema(sqlDefinition.hasSchemaSupport()? database.getSchema() : null).auto().build();
public EntityManager buildEntityManager(final String subsidiary) throws Exception{
DatabaseDTO database = this.databaseManager.getByDatasourceName(subsidiary);
if(database == null) throw MessageError.build(MessageError.NOT_EXIST);
AbstractDefinition sqlDefinition = SqlDefinitionProvider.build(database.getType().getValue());
try {
Class.forName("org.postgresql.Driver").getName()
log.info("Driver founded");
}catch (Exception e){
log.error(e.getMessage());
return EntityManagerBuilder
.auto()
.build();
package com.tc.labt.sgabs.benchmarkdata.configuration;
import com.atlassian.activeobjects.external.ActiveObjects;
import com.atlassian.activeobjects.internal.EntityManagedActiveObjects;
import com.atlassian.activeobjects.internal.TransactionManager;
import com.atlassian.activeobjects.spi.DatabaseType;
import com.atlassian.sal.api.transaction.TransactionCallback;
import com.google.common.collect.ImmutableMap;
import net.java.ao.ActiveObjectsException;
import net.java.ao.EntityManager;
import net.java.ao.Transaction;
import org.slf4j.Logger;
import org.slf4j.LoggerFactory;
import java.sql.Connection;
import java.sql.SQLException;
import java.util.Map;
import java.util.Objects;
public final class BusinessActiveObjects extends EntityManagedActiveObjects {
private static final Logger log = LoggerFactory.getLogger(BusinessActiveObjects.class);
private static final Map<String, DatabaseType> DATABASE_PRODUCT_TO_TYPE_MAP = ImmutableMap.<String, DatabaseType>builder()
.put("H2", DatabaseType.H2)
.put("HSQL Database Engine", DatabaseType.HSQL)
.put("MySQL", DatabaseType.MYSQL)
.put("PostgreSQL", DatabaseType.POSTGRESQL)
.put("Oracle", DatabaseType.ORACLE)
.put("Microsoft SQL Server", DatabaseType.MS_SQL)
.put("DB2", DatabaseType.DB2)
.build();
private BusinessActiveObjects(final EntityManager entityManager) {
super(entityManager, new TransactionManager() {
@Override
public <T> T doInTransaction(final TransactionCallback<T> callback) {
try {
return new Transaction<T>(entityManager){
public T run() { return callback.doInTransaction(); }
}.execute();
} catch (SQLException e) {
throw new ActiveObjectsException(e);
}, findDatabaseType(entityManager));
private static DatabaseType findDatabaseType(final EntityManager entityManager){
Connection connection = null;
try{
connection = entityManager.getProvider().getConnection();
String dbName = connection.getMetaData().getDatabaseProductName();
for(Map.Entry<String, DatabaseType> entry : DATABASE_PRODUCT_TO_TYPE_MAP.entrySet()){
if(dbName.toUpperCase().startsWith(entry.getKey().toUpperCase()))
return entry.getValue();
}catch(Exception e){
}finally{
if(connection != null){
try{
connection.close();
}catch (SQLException e){
log.error(e.getSQLState());
return DatabaseType.UNKNOWN;
public static ActiveObjects build(final EntityManager entityManager){
log.error(Objects.nonNull(entityManager));
return new BusinessActiveObjects(entityManager);
Please need help, advice, ...
