I need to customize the resolution field values on Resolve Issue Screen based on the Issue Type.
If Bug is type I want only fix,won't fix and soon.
Otherwise for Remaining Issue Types, some other resolution field values need to be displayed.
Please provide any plugin somewhat related to only this issue.
Did you try Behaviours plugin and the script I provided you here https://answers.atlassian.com/questions/118834/is-there-any-plugin-for-customizing-resolutions-based-on-the-issue-type ?
I dont think there is any other way of achieving this , you will need to do it either using javascript or groovy script in behaviours plugin .
But using scripts may lead to incompatibility to some browsers
Depends on the script you are using ... You will need to do a good testing on the browsers JIRA is compatible ... Even JIRA requires Javascript to be enabled on the browser .
I cant think of anyway this can be done via a plugin , If you dont want to use a script you might have to make changes in the JIRA source/files . Also note that these changes will have to be manually made during every upgrade of your JIRA
How can I get JIRA source files?
There is the option C. Faysal gave as well. Everything else requires code, whether that's injecting javascript or hacking core code. I don't think this is something that's possible in a plugin (although a plugin might be one way to get your javascript in)
This is a duplicate question of https://answers.atlassian.com/questions/118834/is-there-any-plugin-for-customizing-resolutions-based-on-the-issue-type where i had suggested the use of Workflow properties but i guess here all the issuetypes share a single workflow
Yes Mizan, but by using workflow properties, need to define the workflow for each issue type.
Also the Behaviours Plugin involves a lot of groovy scripting & it make me to learn groovy script which is time consuming.
Separate workflows and using workflow properties is a very good option because some day you will define a separate workflow for each issuetype. Also there can be more customization done to the workflows. And no coding needed. No worries during upgrades.
