Pop up messages on specific transitions possible?
Melvin Vasquez October 5, 2015
Hi
I just get JIRA Toolkit messages working fine but I don't want the same message on every transition, I need an specific message on the right transition.
Is there a way to get it work in that way?
Nic Brough -Adaptavist-
October 5, 2015
Every transition can have a different transition screen.  Create a screen without the message field on it, and another with the field.  Then use the "with" screen on your specific transition, and the "without" for all the other transitions.
