I have two custom field named as Epic-QC(Single line text field) and Detailed functionality list(Select list custom field).
I need to populate Epic-QC(Single line text field) to Detailed functionality list(Select list custom field).
So please can you help us on this.
Thanks.
You can do this with the following behaviours script attached to the "Epic-QC" field:
import com.onresolve.jira.groovy.user.FieldBehaviours import groovy.transform.BaseScript @BaseScript FieldBehaviours fieldBehaviours def epicField = getFieldById(getFieldChanged()) def detailedListField = getFieldByName("Detailed Functionality List") def epicValue = epicField.getValue() if (epicValue) { detailedListField.setFieldOptions([(epicValue): epicValue]) } else { detailedListField.setFieldOptions(["-1": "None"]) }
It will set whatever value is in the "Epic-QC" field into the "Detailed Functionality List" field. If no value is set the value in the list will be None.
Dear @Adam Markham [Adaptavist],
Thank you so much for your response.
I tried your above behaviours script and it is populating "Epic-QC" field value into "Detailed functionality list" but when i click on update i got the error .Please refer the below attachment for the same.
Also When "Epic-QC" field value get populate into "Detailed functionality list" then it should not remove the previous drop-down option values.
Thanks and Regards,
Suchit R Kharatmol.
Those numbers next to the values are the option ids, you need to match it with the corresponding one, So for suchit your code needs to be:
import com.onresolve.jira.groovy.user.FieldBehaviours import groovy.transform.BaseScript @BaseScript FieldBehaviours fieldBehaviours def epicField = getFieldById(getFieldChanged()) def detailedListField = getFieldByName("Detailed Functionality List") def epicValue = epicField.getValue() if (epicValue) { detailedListField.setFieldOptions(["11400": epicValue]) } else { detailedListField.setFieldOptions(["-1": "None"]) }
I did not see error myself when testing this. Have you another behaviour enabled for this field or another validator?
I tried your above behaviours script and it is populating "Epic-QC" field value into "Detailed functionality list". Its working fine now without any errors.
Thanks a lot for your help Adam.
Thanks and Regards,
Suchit R Kharatmol
Great, glad you got it working. If you want the other options you need to specify them like so in the setFieldOptions call.
detailedListField.setFieldOptions(["11400": epicValue, "11313": "demo"])
Hi @Adam Markham [Adaptavist] ,
Thank for your response.
Yes Detailed functionality list is the single list select list custom field. I want to populate "Epic-QC" value in the Detailed functionality list single list field .
Thanks and Regards,
Suchit R Kharatmol.
Is this a single select list? Do you want to populate the list with values in "Epic-QC" or select one in the list based on "Epic-QC" value?
Hi @Jamie Echlin [Adaptavist],
I tried the below behavior script.
FormField epic=getFieldByName("Epic-QC"); String epic_value=epic.getValue(); log.error("----------- Epic-QC value is---"+epic_value) FormField dfl=getFieldByName("Detailed Functionality List").setFormValue(epic_value);
Thanks and Regards,
Suchit R Kharatmol.
What have you tried so far?
Get Certified! ✍️Online forums and learning are now in one easy-to-use experience.
