×I created a custom field that is a drop down list and noticed that it contains the value 'None'. I do not want this in the list, but rather only use the values I created in the drop down list. Is this possible?
You have to make the field required, then the 'none' won't be there anymore.
No, it is still there after I make it required in field configuration
See my answer from 2019 - you also have to define a default value.
At the moment (in Jira 7 and 8) you have to make the field mandatory and give it a default value - then the "None" disappears.
Using scriptrunner behavior, you can use something like below.
Set the field as required/not required (on behavior side, not JIRA's field configuration), depending on your use case.
In my case, I want my severity field to be set as required only on a certain project, without having to create additional field configuration (as I have one massively shared field configuration - for process standard in my company). So I set the severity field as required through behavior, but the 'none' option stills show. So, use below :script
import com.atlassian.jira.issue.customfields.manager.OptionsManager
def optionsManager = ComponentAccessor.getComponent(OptionsManager)
def severity = getFieldByName("Severity")
severity.setAllowInlineEdit(false)
def sevcustomField = customFieldManager.getCustomFieldObject(severity.getFieldId())
def sevconfig = sevcustomField.getRelevantConfig(getIssueContext())
def sevOptionsOriginal = optionsManager.getOptions(sevconfig)
/*define the select list manually, do not include the 'none'*/
def sevOptionsCustYes = sevOptionsOriginal.findAll { it.value in ['Critical', 'Serious','Medium','Low'] }
severity.setFieldOptions( sevOptionsCustYes )
Thanks @Azfar Masut
We don't have Script Runner on our server, but I can try and persuade our board to invest in it. But when I tested on my own personal instance it seemed to do the trick.
Regards
@Liam Maeder - great to hear that! Do help to upvote my answer if it helps!
btw, scriptrunner is worth the investment, especially if you're supporting large number of users (in my case, 10k userbase). Lots of other customization can be done with SR to deal with the small custom request from your users. I would say, go for it!
The behavior script worked perfectly fine.
Thanks @Azfar Masut .
The behavior script was very useful and it worked fine.
Thanks @Azfar
Hello @Azfar Masut ,
This solution seems to be the one that I need, but I have a question. You state that I need to set the field as required in behavior. I'm not sure how to do that, I know about the field config setting required, but not about "behavior." Can you point me in the right direction please?
@Kevin Middleton sorry for being unclear on that part. Setting required/not is optional depending to your use case. The point is, for that config, instead of using field configuration to control either a field is required or not, use behavior instead. For behaviour, see https://docs.adaptavist.com/sr4js/latest/features/behaviours/behaviours-tutorial . You'll require scriptrunner add-on for this
A dirty workaround - Make the custom field Mandatory and "None" option will disappear.
Only solution (without any coding) is to:
You can also add an option that's just a space and make that the default value. Of course, you still need to make the field mandatory
Step one: Make the custom field not "Multi-select value" meaning, "None" in that selection as part of edit the custom field.
Step two: Make the field mandatory/required
This works for me
@Azfar MasutMasut,
I am using the below code to display options of the Location field but I see none option by default on the request form but I do not want that instead, I want International to show up. Can you please help.
import com.onresolve.jira.groovy.user.FieldBehaviours
import com.onresolve.jira.groovy.user.FormField
def optionsManager = ComponentAccessor.getOptionsManager()
def Location = getFieldById("customfield_14444")
Location.setAllowInlineEdit(false)
// Get access to the required custom field and options managers
def customField = customFieldManager.getCustomFieldObject(Location.getFieldId())
def config = customField.getRelevantConfig(getIssueContext())
def options = optionsManager.getOptions(config)
def optionsMap = options.findAll {
it.value in ["International",
"United States"] // list of options you want to show
Location.setFieldOptions(optionsMap)
looks correct to me, can you double check and ensure the location field doesnt have 'none' set as default? (from the JIRA custom field setup page)
Try setting International as default instead. Is the 'None' option still showing after that?
Hi Jobin ,
Do you know what will be a javascript/groovy solution for making "None" as the first option . I have raised a question here
Thank you
I have a similar issue where i keep getting this none option but i have a default value already set and mandatory, yet the none option is still present. Is there no there way to get rid of it
I'm having the same issue as @Liam Maeder. The Field is required, but none still shows up; what's worse, it acknowledges 'none' as acceptable, so it basically renders the 'required' part of the field useless.
