Post Function Increment Counter
Richard Duffy
November 17, 2019 edited
Hi
Looking for some help with a post function script:
Tools: Scriptunner JSU
Version: Jira 8.4.2
Problem statement: I want to enable a counter based on a specific workflow transition, eg - When the reopen transition is fired from the status fixed - add 1 to the counter field
Method:  (Custom script post function)
Field created: Scripted field (customfield_13502) - number searcher
Code:
import com.atlassian.jira.ComponentAccessor
import com.atlassian.jira.issue.customfields.CustomFieldType
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.ModifiedValue
import com.atlassian.jira.issue.util.DefaultIssueChangeHolder
import com.atlassian.jira.issue.util.IssueChangeHolder
import com.atlassian.jira.issue.IssueManager
IssueManager issueManager = ComponentAccessor.getIssueManager()
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
CustomField cf = customFieldManager.getCustomFieldObject("customfield_13502")
Double val = (issue.getCustomFieldValue(cf) as Double)
if ( val == null)
val = 1
else
val = val + 1
IssueChangeHolder changeHolder = new DefaultIssueChangeHolder();
cf.updateValue(null, issue, new ModifiedValue(issue.getCustomFieldValue(cf),val), changeHolder)
Thanks in advance
Rich
Leo
Hi @Richard Duffy
maybe you can try this , since there is already re-index function in post-function order need not to use changeholder. you can use that if you are working with listerners
def val = issue.getCustomFieldValue(cf) as Integer
if (val)
val = val + 1
else
val = 1
issue.setCustomFieldValue(cf, val)
BR,
Leo
Richard Duffy
Thanks for quick reply Leo
if (val)
val = val + 1
else
val = 1
I have edited the script to the above. Still no luck
Is my Custom field correct using "Scripted Field" with number template?
Leo
Are you trying with scripted field?
if so you need to place script in it's place. but I don't think for your requirement scripted field is required as you want to update this field only on particular workflow transition
my bad I missed to notice scripted field you mentioned :(
I would suggest you to create Number Field(custom field not scripted field) and use this post-function script
BR,
Leo
Richard Duffy
Yes correct regards requirement. I have changed the field to Number field.
Getting workflow error now when executing the transition
Error occurred while creating issue. This could be due to a plugin being incompatible with this version of JIRA. For more details please consult the logs, and see: http://confluence.atlassian.com/x/3McB java.lang.Integer cannot be cast to java.lang.Double
It seems that you have tried to perform an illegal workflow operation.
If you think this message is wrong, please contact your Jira administrators.
Leo
ah gotcha, seems like I was wrong
you must go with Double instead of Integer as you were before
Double val = issue.getCustomFieldValue(cf) as Double
Richard Duffy
Great Leo, its working now. Thanks for your guidance
Aradhya Kahate
September 11, 2023
Hi Leo,
For me it is only incrementing till value2 not more than that.
Can you suggest Something?
Register now
