Post-Function ScriptRunner script to update summary with name of following month
Chris Ghazanchian
Hello! I am new to scriptrunner and programming in general so I am struggling with how to achieve what I would like.
Here's my scenario-
I have issues within my project that have a custom date field "Billing Cycle Date".
I would like to run a workflow post function script which will take the billing cycle date, calculate what the next month is, and then append the name of the month into the summary.
So, let's say for a given issue:
Summary: Issue1
Billing Cycle Date: 3/5/2018
Upon workflow transition, postfunction script runs and sets Summary to "Issue1 - April"
I have spent multiple days trying to figure this out but nothing is working properly, any guidance would be greatly appreciated!
Alexey Matveev
March 5, 2018
Could you provide one of your scripts, which is not working?
Chris Ghazanchian
I figured this much out, which worked.
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.UpdateIssueRequest
CustomFieldManager customFieldManager = ComponentAccessor.getCustomFieldManager()
String field1Value = (String)issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Cycle Date"))
issue.setSummary(field1Value)
But now, I need it to add exactly one month to the date (not 30 days), and then convert the month to the actual name and set it in the summary.
Not sure if that's possible, I'm exploring other options (combining multiple automation tasks or multiple fields).
Alexey Matveev
March 8, 2018
Like this
java.sql.Timestamp field1Value = (java.sql.Timestamp)issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("Cycle Date"))
field1Value.setMonth(field1Value.getMonth() + 1)
Chris Ghazanchian
Thank you for your response, I truly appreciate it!
I am getting the following error, and am unsure what it means.
Alexey Matveev
March 9, 2018
issue.setSummary(field1Value.toString())
Chris Ghazanchian
This is the error I got after using that script.
2018-03-10 11:03:38,576 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2018-03-10 11:03:38,577 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: RAR-4, actionId: 41, file: <inline script>
java.lang.NullPointerException
 at com.atlassian.jira.issue.IssueImpl.getCustomFieldValue(IssueImpl.java:896)
 at com.atlassian.jira.issue.Issue$getCustomFieldValue$6.call(Unknown Source)
 at Script119.run(Script119.groovy:7)
I modified the script to use getCustomFieldObject (with the customfield's id) instead of getCustomFieldObjectByName, and then got this error.
2018-03-10 11:13:02,566 ERROR [workflow.ScriptWorkflowFunction]: *************************************************************************************
2018-03-10 11:13:02,581 ERROR [workflow.ScriptWorkflowFunction]: Script function failed on issue: RAR-4, actionId: 41, file: <inline script>
org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object 'August 24, 2018' with class 'java.lang.String' to class 'java.sql.Timestamp'
 at Script125.run(Script125.groovy:7)
Alexey Matveev
March 10, 2018
What is your Jira version?
Chris Ghazanchian
7.6.2
Chris Ghazanchian
My mistake, I apologize. That script ended up working, the field I was using it on was just a text field (I forgot I had tried a few other things before implementing the new script).
Now it is working great except it is putting the whole date and time into the summary. I would only like to put the name of the month.. for example if the date is June 1st, 2018, then only put "July"(next month) in the summary. Is that possible? I'm trying to research it myself right now.
Alexey Matveev
March 10, 2018
import java.text.SimpleDateFormat
SimpleDateFormat monthFormatter = new SimpleDateFormat("MMMM");
java.sql.Timestamp field1Value = (java.sql.Timestamp)issue.getCustomFieldValue(customFieldManager.getCustomFieldObjectByName("CycleDate"))
issue.setSummary(monthFormatter.format(field1Value))
German Rodriguez Bolanos October 10, 2018
Hi have the same issue:
any ideas? basically I need to set a value for the Description, but I don't now which command do i need for this, thanks
David Willson December 2, 2021
Did you ever find out? I am looking to do the same.
