Hello we have added all free add ons or plug ins for JIRA in our Jira. One was good for adding post functions in JIRA . It was good so i could add the post function to be able to set resoultion field to Done, when issue is closed, to my features. Now i tried to do the same for my sub tasks but the field add post function does not appear. what happens ?
Hi Corinna
Can you please include a screenshot of the workflow that you are trying to edit showing the resolve/close transition that you wish to set the resolution on. This will help troubleshoot your problem.
Phill
Set resolution to X is built into JIRA by the way, you don't need any add-ons - try adding the "set field value" post-function when you are in "edit" mode in the workflow.
