Post function script get value of simple selection list
Arthur SALMON
October 1, 2019 edited
Hi community !
I am trying to set up a post-function script in Jira workflow using scriptRunner.
I made it work for multiple selection list but it is not working for simple selection list...
import com.atlassian.jira.ComponentManager;
import com.atlassian.jira.issue.CustomFieldManager;
import com.atlassian.jira.issue.Issue;
import com.atlassian.jira.component.ComponentAccessor;
import com.atlassian.jira.issue.MutableIssue;
import com.atlassian.jira.issue.comments.CommentManager;
import com.atlassian.jira.issue.fields.CustomField;
import com.atlassian.jira.util.ImportUtils;
import com.atlassian.jira.user.util.UserManager;
import com.atlassian.crowd.embedded.api.User;
import com.atlassian.jira.user.UserUtils
def String m_assignee = 'Unassigned';
def cfIssueType = issue.issueType.name;
def cfLoc = ComponentAccessor.getCustomFieldManager().getCustomFieldObjectByName("Supplier Location");
Map cfLocation = issue.getCustomFieldValue(cfLoc) as Map
String first = cfLocation.get(null);
switch(first){
case 'North America':
m_assignee = 'iron.man';
break;
case 'Other':
m_assignee = 'spider.man';
break;
default :
m_assignee = 'super.man';
break;
issue.setAssigneeId(m_assignee);
I will have to combine this code with some other but first, I'm trying to make this block worked.
Can anyone give support on that please?
Nic Brough -Adaptavist-
October 1, 2019
You are very close - most people with this question don't realise the value from a select list is an array of elements.  (I'm not sure it's a map, I've just used arrays and collections in the past, so I'm not qualified to comment if that could be an extra problem)
The contents of the field is a list of one, but for a select list, the elements are "options", not strings, so your "first" variable will not contain what you expect. I think you need to treat it as an option.
The code here is what I tend to "borrow" nowadays - https://library.adaptavist.com/entity/update-priority-based-on-a-custom-field
Arthur SALMON
Ok, I am not a hundred percent sure about what is the real difference but at least, I made it work thanks to you ! What I don't get is why is it working like this for "Single Select List" and not for "Cascading Select List"...?
Here is the code :
import com.atlassian.jira.config.PriorityManager
//Line added 1
import com.atlassian.jira.issue.customfields.option.LazyLoadedOption
//Line added 2 (just added "as LazyLoadedOption")
def first = issue.getCustomFieldValue(cfLoc) as LazyLoadedOption;
switch(first){
case "North America":
break
case "Other":
break
default:
break
October 2, 2019
It's about different java objects being stored, and objects in java can have very different properties and behaviours.
For example, a text field holds a string of characters which works as you would expect.  Numeric fields hold simple numbers.  These objects are significantly different because you can't do things like multiply strings together, or put letters (other than scientific notations) into numbers.
The objects that Jira has as "options" are more complex again.  They are made up of a unique id, a display name, a type, flags to say if they are enabled or not, methods to read and update these things, and data to say what their parent option is if they are an option in the second part of a cascading-select list.
A cascading select is a single value still, but the option you get back is more complex, and you need to look at the parent as well as child option.
https://docs.atlassian.com/software/jira/docs/api/8.4.0/index.html?com/atlassian/jira/issue/customfields/option/Options.html covers the basics.
Like • 2 people like this
