I would like to set a due date on create from a post function however I can not get this to work.
The issue is created via email into the system so I tried to add a post function to set the due date to current date.
There are two possible troublems:
Let's specify the trouble.
This is what I tried so far:
I created a post function on Create called Update parameters of the opy value from other field function for this transition.
Source filed = Created and Destination filed = Due Date Option copy with same issue.
In to post function list I have placed it from 1st in list to bottom of list and ever spot in between and it in not coping the created date into the due date.
1 Created the issue originally
2. Re-index and issue to keep indexes in sync with database
3. Fire a Issue Created event that can be processed by the listeners
4 (my post function)
Help us plant more trees
