Posting Scripts on Custom Fields
Elif Alverson
I have created " Custom fields " that users can post their scripts however it does not look correct. What should I do to change the text field that the script looks like a real script.
Thank you.
Grigory Salnikov
February 5, 2019
Hello, @Elif Alverson
I'm sorry, but what do you mean by "like a real script"? Please, be a little bit more descriptive.
Thanks in advance.
Elif Alverson
Sure.
When we post our scripts it seems like , there are not spaces  between the lined, or lines are all cramped together.
What text format should we use to post our scripts ?Is this format is available for custom fields?
Does that make any sense?
Grigory Salnikov
February 5, 2019
Yes, it does.
Do you use Text Field (multi-line)?
I think you might find the following information really helpful:
Text Formatting Notation Help
Like Elif Alverson likes this
Elif Alverson
I would like to change the Custom Multi Line text field to the Custom Multi Line Code field? Is that possible?
Grigory Salnikov
February 6, 2019
Hello!
Usually, you can it's not so difficult Changing Custom Field Types in JIRA, but I doubt there's such a type as "Custom Multi Line Code".
