PowerScripts - UserInRole
Hi!
In a project I have a process of delegating a task to another project. I need to check if the selected user is in the Developers role in that project.
I found isUserInRole(user,project, role). But in the user need to register the user name or  key.
How can I pull the key out of the field?
Amelie Winkler [Appfire]
Hi @Ступникова Анна Александровна
If you use a standard user picker field, it should be quite simple.
Run the following script from the SIL Manager (make sure to specify the issue context via Run Configuration)
string usertocheck = customfield_11606 ; // here custom field Id needs to be replaced with actual id
string currentproject = project;
string role="Developers";
return isUserInRole(usertocheck , currentproject , role);
