Preselecting fields when creating Jira issues?
Markus Lepper
April 15, 2012
The deep link to create a task (issuetype 3) in my project xxx (pid=10032) is e.g. https://xxx/jira/secure/CreateIssue.jspa?pid=10032&issuetype=3&Create=Create
Could I extend this link to have some more Jira-inbuilt fields preselected; e.g.
...&component=12345 or &priority=2 or &securitylevel=4
(Same question for custome fields)
Thanks a lot & BR,
Markus
JamieA
April 15, 2012
Markus Lepper
April 15, 2012
Thanks Jamie!
Didn't know this page so far.
Played yround a bit and I think this is for another purpose= fully generate issues with defined fields set.
I need to have the "Create issue screen" with some fields pre-populated and the user could add more data before pressing "Create issue" button.
I need to extend this URL: https://xxx/jira/secure/CreateIssue.jspa?pid=10032&issuetype=3&Create=Create
Adding e.g. "&summary=test" does not add the text
Link from your linked page uses another script: http://xxx.atlassian.com/secure/CreateIssueDetails!init.jspa?pid=10032&issuetype=3
Any idea?
Markus
JamieA
April 15, 2012
Yeah, you need the !init bit, otherwise if all fields are present, it will commit the issue. It's fiddly, I went through this a while ago, but it should be possible.
JamieA
April 16, 2012
If you have an example that would probably be much appreciated by other people...!
Markus Lepper
April 16, 2012
Thanks Jamie,
took a bit time to play around but now it's working ;-)
Regards, Markus
Markus Lepper
April 16, 2012
Sure :-)
https://xxx/jira/secure/CreateIssueDetails!init.jspa?pid=10032&issuetype=3&priority=2&security=10524&components=10493&summary=Person%20xxx%20needs%20access%20to%20system%20yyy%20with%20rights%20zzz
works for requesting access rights.
Like • # people like this
