Preventing JIRA from saving insecure data on site or in logs
Mathieu Castonguay January 16, 2018
Hello everyone,
I'm working right now on a plugin for JIRA that blocks any potential number of 10 digits that begin with the number 9, for example: it's supposed to block the number "9876543217"
The issue I have right now is I realize JIRA saves everything you write in the fields of JIRA, like the search field and Labels field for example. It saves that information in some logs called "access_log.2018.01.16" but that's something I don't want to happen because it could be a potential breach.
I want to know if there are a way to make sure that information is not saved in the logs or at least being censored immediately?
somethingblue
January 17, 2018
Hi Mathieu,
The JIRA Anonymizer anonymizes the following data:
The anonymizer currently replaces the following text with x's:
  • Issue summary, environment, and description.
  • Comments, work logs, change logs.
  • Project descriptions.
  • Descriptions for most elements (notification schemes, permission schemes, resolutions).
  • Attachment file names.
  • "Unlimited text" custom fields.
This could perhaps be incorporated into a script to run whenever X happens or on a periodic basis.
Branden
Mathieu Castonguay January 17, 2018
Is JIRA Anonymizer can affect the Activity Stream too? For example, writing "9876543217" in a text field will be replaced with x's for that text field and the Activity Stream as well?
