×Hi all
Every time I create an issue, regardless on the type, the priority is set to Major per default. How can I change this?
This is only configurable in Setting which is available only for Jira Admin
If you are one of the Jira Admin for the Site
Navigate to the Cog Icon at the top right and choose "Issues" option
Under Priority in Issue Attributes section you can choose which one to be default
If you don't have Jira Admin permission, check with your Jira Admin to make the changes
Please note this will affect all other projects as well for default option
Pramodh
Thanks you for your help
open project settings in left side of project.
click on Priorities on right side click on default priority scheme .
open that scheme there you can choose default one.
Thanks.
