Priority order is incorrect
Barry van Oudtshoorn August 9, 2011
I've just upgraded from 4.3.4 to 4.4, and I now find that in all issue lists, ordering by priorities (desc) goes in the order
  • Major
  • Critical
  • Blocker
  • Minor
  • Trivial
I've checked the priority order is correctly sorted on the Issue Attributes / Priorities admin screen, and even tried moving them up and down to see if that would fix it. No dice -- this ordering seems to be fixed. Checking the "priority" table in the database shows that the sequence field has the correct ordering (as does the id), but interestingly, the natural order is as follows (sequence/id in brackets):
  • (4) Minor
  • (5) Trivial
  • (1) Blocker
  • (2) Critical
  • (3) Major
It looks to me as though there's an ORDER BY clause that's missing... :/
Any ideas on how to go about getting this rectified? Needless to say, it's extremely frustrating.
Barry van Oudtshoorn February 22, 2012
It looks as though this is an issue only for a while after the upgrade... I guess I'll reopen this if I see it again.
Vijay Koleti November 30, 2018
I'm seeing this issue now in Jira version 7.12.1.
My Priority Scheme:
  • CriticalCritical
  • HighHigh
  • MediumMedium
  • LowLow
  • Good To HaveGood To Have(Default)
  • ON-HOLDON-HOLD
JQL "ORDER BY priority DESC" displays:
  • HighHigh
  • MediumMedium
  • CriticalCritical
  • LowLow
Jim Ryan
I'm having this issue also in cloud. `ORDER BY priority DESC` displays issues in this order:
  1. Medium
  2. Emergency
  3. High
  4. Medium
  5. Low
Yes, for some reason the "Medium" ones are split into two different groups, even though I have only one "Medium" priority level.
Druciaki
May 3, 2018
I'm having this issue on the cloud.
Jira 3a3582d9
Any suggestion of how may I fix it?
I've tryed to clear browse cache. No luck so far...
Steve Johnson February 8, 2012
It does indeed seem to be OK in 4.4.4. I was initially seeing bad behavior, but it's working fine now. Never mind.
srinivasp
February 7, 2012
It seems fixed in 4.4.4
Steve Johnson February 7, 2012
Not from my view. I'm running 4.4.4, which I installed just a few days ago.
srinivasp
February 7, 2012
executed project = BUG ORDER BY priority DESC and i got issues in the following order Blocker, Critical, High, Medium and Low.
It seems to be OK now. I don't know what changed. Maybe it was only a transient problem that occured right after I changed all the priorities. Thanks for your comments.
I'm having the same problem. I've set up custom priorities, and the ordering when sorting by priority does not match the order of the priorities in the priority setup area.
I'm having the same problem. I've set up custom priorities, and when sorting by priority, the sort order does not match the ordering set up in the administration screen for priority setup.
