Problem facing with CSV file import to JIRA...
Ram Prayaga February 15, 2012
I am trying to import data from CSV file to JIRA, During the 3 rd step I have encountered with an error shown as below :
Invalid project key PRJA-1: You must specify a unique project key, at least 2 characters long, containing only uppercase letters
And I have changed the key with some new values & tried to import, This time in the first step only I have encountered with error :
java.io.IOException: Malformed CSV stream. Missing [,] near offset 9 after field 0 on line 1
please help me on this.
Thanks in Advance...
Jobin Kuruvilla [Adaptavist]
February 15, 2012
Your CSV is not well formatted it seems? Are you able to open it in Excel?
Ram Prayaga February 16, 2012
Thanks for the Response Jobin. And Yes I am able to open it in Excel. By the way I am using JIRA 4.4.3 working on Windows7...
Fernando Horn
I'm having the same problem. This is my two first lines:
<colgroup><col width="211"> <col width="174"> <col width="264"> <col width="105"> <col width="181"> <col width="157"> <col width="80"> <col width="64"> <col width="138"> <col width="139"> <col width="64"> <col width="239"> <col width="151"> <col span="6" width="64"> </colgroup>
Project Key Summary Priority Created Component/s Description Category Status Browser/s or Device/s Operational system/s Attachment 1 Attachment 2 Attachment 3 Attachment 4 Attachment 5
Buscape Mobile iOS BUSCMOB-1 [Texto] Alguns textos na tela inicial estão em plural e outros não Minor 17/07/2012 09:54 Tela Inicial EXPECTED:
Um padrão na tela inicial, todos produtos no plural ou nenhum.
ACTUAL:
Alguns produtos na tela inicial está em plural e a maioria não.
User Interaction Open IPhone 3GS iOS attachments/BUSCMOB-1/21309.jpg attachments/BUSCMOB-1/21307.jpg attachments/BUSCMOB-1/21308.jpg attachments/BUSCMOB-1/21311.jpg attachments/BUSCMOB-1/21310.jpg
Buscape Mobile iOS BUSCMOB-2
[Botões] Botão 'Busca' não é
intuitivo
Major 17/07/2012 10:24 Tela Inicial EXPECTED:
Botão 'Busca' poderia ser chamado de 'Home' visto que o botão 'Busca' retorna para a página inicial.
ACTUAL:
Botão 'Busca' passa a impressão de ser um título da seção e não um botão que retorna a página inicial.
User Interaction Open iPad iOS attachments/BUSCMOB-2/21304.png
Ram Prayaga February 20, 2012
Thanks Nic, It is working now. The file is not formatted correctly the fields are seperated by a semicolon instead of comma.
Nic Brough -Adaptavist-
February 20, 2012
That's not CSV - could you give us the plain text CSV, not just formatted data? We need to see exactly what Jira is reading from the file, not what you think it should be reading.
<colgroup><col width="64"><col width="37"><col width="78"><col width="88"></colgroup>
Project Key Summary Issue Type
ProjectA PJA Summary1 Requirement
ProjectA PJA Summary2 Defect
ProjectA PJA Summary3 Task
Here I am providing my CSV file data...
February 20, 2012
As Wojciech says, we need to see your data to tell you where the problem is? The error message is telling you that the data is incorrectly formatted, so we need to see it to be able to point you at the error.
Hi Wojciech Seliga, thanks for your response. Now it is working fine for me. The 1st issue that I have mentioned is due to invalid format of CSV file.
But for the IOException mentioned above I am still getting that, if I do any modification to the field of the CSV file which I have already used and tried to use again...
I am using JIRA Importers Plugin 3.5.3...
Wojciech Seliga
February 17, 2012
Could you please paste here first 2 lines of your CSV file?
Another question: which version of JIRA Importers Plugin do you use with JIRA instance? It's probably 3.5.x, but recently we were shuffling with CSV parser libraries used, so this information is quite important.
Register today
