Problem in install jira data center in centos
sina rahemi September 5, 2023
in install step after enter database parameter i get this error
my test connection in database was successful
I tried several times but I don't know where my problem is
I will be grateful for your guidance
os: centos 9
db: postgresql 15
create db with this:
CREATE USER jiradbuser PASSWORD '4YNQcQt95sH9vWKr';
CREATE DATABASE jiradb WITH ENCODING 'UNICODE' LC_COLLATE 'C' LC_CTYPE 'C' TEMPLATE template0;
GRANT ALL PRIVILEGES ON DATABASE jiradb to jiradbuser;
in pg_hba.conf change IPv4 local connections to md5
host all all 127.0.0.1/32 md5
dbconfig.xml:
<jira-database-config>
<name>defaultDS</name>
<delegator-name>default</delegator-name>
<database-type>postgres72</database-type>
<schema-name>public</schema-name>
<jdbc-datasource>
<url>jdbc:postgresql://localhost:5432/jiradb</url>
<driver-class>org.postgresql.Driver</driver-class>
<username>jiradbuser</username>
<password>4YNQcQt95sH9vWKr</password>
<pool-min-size>40</pool-min-size>
<pool-max-size>40</pool-max-size>
<pool-max-wait>30000</pool-max-wait>
<validation-query>select 1</validation-query>
<min-evictable-idle-time-millis>60000</min-evictable-idle-time-millis>
<time-between-eviction-runs-millis>300000</time-between-eviction-runs-millis>
<pool-max-idle>40</pool-max-idle>
<pool-remove-abandoned>true</pool-remove-abandoned>
<pool-remove-abandoned-timeout>300</pool-remove-abandoned-timeout>
<pool-test-on-borrow>false</pool-test-on-borrow>
<pool-test-while-idle>true</pool-test-while-idle>
<connection-properties>tcpKeepAlive=true</connection-properties>
</jdbc-datasource>
</jira-database-config>
log file:
https://1drv.ms/u/s!Ahbf0eDwCH70guclZawK4FNwWQS6rw?e=iG1wbj
Dirk Ronsmans
@sina rahemi ,
Your instance is starting so you should be able to see in the logs what the error is that prevents it from loading further.
Can you check your logs what the error/information is?
