Sign up Log in
Problem integrating Jira and LDAP
Mezzanotte December 25, 2011
Hello everyone,
I've setup Jira to use LDAP (Open LDAP, read-only). When I synchronized, the groups and users are correctly found. But the association between users and groups was not found.
The Group Schema Settings is configured as a PosixGroup. I guess I'm not setting the correct values for the Membership Schema Settings:
My Group Schema Settings:
<label style="float: left; display: block; left: -240px; line-height: 1; margin-right: -230px; padding-top: 4px; position: relative; width: 230px; text-align: right; word-wrap: break-word;" for="configure-ldap-form-ldapGroupObjectclass">Group Object Class:required</label><input id="configure-ldap-form-ldapGroupObjectclass" class="text " style="margin-top: 0px; margin-right: 5px; margin-bottom: 0px; margin-left: 0px; width: 250px; color: #000000; padding: 2px;" type="text" name="ldapGroupObjectclass" value="posixGroup"/>
LDAP attribute objectClass value to search for when loading groups.
<label style="float: left; display: block; left: -240px; line-height: 1; margin-right: -230px; padding-top: 4px; position: relative; width: 230px; text-align: right; word-wrap: break-word;" for="configure-ldap-form-ldapGroupFilter">Group Object Filter:required</label><input id="configure-ldap-form-ldapGroupFilter" class="text " style="margin-top: 0px; margin-right: 5px; margin-bottom: 0px; margin-left: 0px; width: 250px; color: #000000; padding: 2px;" type="text" name="ldapGroupFilter" value="(objectclass=posixGroup)"/>
The filter to use when searching group objects.
<label style="float: left; display: block; left: -240px; line-height: 1; margin-right: -230px; padding-top: 4px; position: relative; width: 230px; text-align: right; word-wrap: break-word;" for="configure-ldap-form-ldapGroupName">Group Name Attribute:required</label><input id="configure-ldap-form-ldapGroupName" class="text " style="margin-top: 0px; margin-right: 5px; margin-bottom: 0px; margin-left: 0px; width: 250px; color: #000000; padding: 2px;" type="text" name="ldapGroupName" value="cn"/>
The attribute field to use when loading the group name.
<label style="float: left; display: block; left: -240px; line-height: 1; margin-right: -230px; padding-top: 4px; position: relative; width: 230px; text-align: right; word-wrap: break-word;" for="configure-ldap-form-ldapGroupDescription">Group Description Attribute:required</label><input id="configure-ldap-form-ldapGroupDescription" class="text " style="margin-top: 0px; margin-right: 5px; margin-bottom: 0px; margin-left: 0px; width: 250px; color: #000000; padding: 2px;" type="text" name="ldapGroupDescription" value="description"/>
My Membership Schema Setting:
<label style="float: left; display: block; left: -240px; line-height: 1; margin-right: -230px; padding-top: 4px; position: relative; width: 230px; text-align: right; word-wrap: break-word;" for="configure-ldap-form-ldapGroupUsernames">Group Members Attribute:required</label><input id="configure-ldap-form-ldapGroupUsernames" class="text " style="margin-top: 0px; margin-right: 5px; margin-bottom: 0px; margin-left: 0px; width: 250px; color: #000000; padding: 2px;" type="text" name="ldapGroupUsernames" value="memberUid"/>
The attribute field to use when loading the group members from the group.
<label style="float: left; display: block; left: -240px; line-height: 1; margin-right: -230px; padding-top: 4px; position: relative; width: 230px; text-align: right; word-wrap: break-word;" for="configure-ldap-form-ldapUserGroup">User Membership Attribute:required</label><input id="configure-ldap-form-ldapUserGroup" class="text " style="margin-top: 0px; margin-right: 5px; margin-bottom: 0px; margin-left: 0px; width: 250px; color: #000000; padding: 2px;" type="text" name="ldapUserGroup" value="memberOf"/>
The attribute field to use when loading a user's groups.
<fieldset class="group " style="border-style: initial; border-color: initial; border-width: initial; position: relative; clear: both; min-height: 1.6em; color: #333333; font-family: arial, tahoma, verdana, sans-serif; font-size: 13px; line-height: 18px; padding: 0px; margin: 0px;"><legend>Use the User Membership Attribute:</legend>
<input id="configure-ldap-form-ldapUsermembershipUse" class="checkbox " style="margin-top: 0px; margin-right: 2px; margin-bottom: 0px; margin-left: 0px; border-width: initial; border-color: initial; float: none; width: 15px; height: auto; vertical-align: middle; position: static; border-style: none; padding: 0px;" type="checkbox" name="ldapUsermembershipUse" value="true"/> <label style="float: none; display: inline; left: 0px; line-height: 1; padding-top: 4px; position: static; width: 230px; text-align: right; word-wrap: break-word; margin: 0px;" for="configure-ldap-form-ldapUsermembershipUse">When finding the user's group membership</label>
</fieldset>
For the Group Member Attribute I tried with uniqueMember and member without success.
Am I doing something wrong?
Thx,
Mezza
</label>
Mezzanotte January 9, 2012
I solved my problem.
It was just a matter of configuration. It worked with this attributes:
directory type: Open LDAP (Read-only Posix Schema)
username attribute: uid
user membership attribute: uid
Michael Schneider January 17, 2012
After you have made these changes you just pressed the synchronize link? Unfortunately your solution is not working at our installation :(
Mezzanotte January 17, 2012
Yes After the changes, I synchronized and it worked. How are your settings?
Leo Diaz _ DEISER
December 25, 2011
Hi Mezza!
I don't know the JIRA roadmap, I ran this query in the 4.4.3 version.
I recommend you to check it previously (test env.). Then, if all works fine, you can go on with it the production env!!
Leo Diaz _ DEISER
December 25, 2011
Hi!
I had the same problem, check the following link, which explains how to associate groups and user directories with a SQL script.
https://jira.atlassian.com/browse/JRA-24161?focusedCommentId=249354&page=com.atlassian.jira.plugin.system.issuetabpanels:comment-tabpanel#comment-249354
Hi Leo,
I'm using Jira 4,4. Is this the only way to fix this?!
Register Now
Upcoming Jira Events
