Problem when searching issues from the code base of an add-on for Jira Data Center
Long Nguyen-Thanh October 2, 2024
Hi every one
I'm a member of a Jira Datacenter  add-on development team.
I am facing the following problem:
From the code base in the back-end of the add-on, I have a scheduled task that is called every 60 seconds. Inside the content of this schedule task, there is a JQL statement that searches for issues that satisfy a certain condition X. Initially, my Jira only has one project A.
The problem is that after I launch Jira Data center with the add-on, the JQL statement in the code base cannot search for issues that satisfy condition X, which are in a newly created project (project B) after lauching Jira Data center. Issues in project A can still be searched. If after creating project B, I restart Jira Data Center, then after restarting I can find all issues in both projects A and B.
Sergei Troshin
October 3, 2024 edited
Hi @Long Nguyen-Thanh
It looks like there are problems with indexing. I hope this code helps or gives some insights:
import com.atlassian.jira.jql.parser.JqlParseException
import groovy.transform.Field
import com.atlassian.query.Query
import com.atlassian.jira.web.bean.PagerFilter
import com.atlassian.jira.jql.parser.JqlQueryParser
import com.atlassian.jira.issue.index.IssueIndexManager
import com.atlassian.jira.bc.issue.search.SearchService
import com.atlassian.jira.util.thread.JiraThreadLocalUtils
import com.atlassian.jira.issue.index.ThreadLocalSearcherCache
@Field final SearchService searchService = ComponentAccessor.getComponent(SearchService.class)
@Field final IssueIndexManager indexManager = ComponentAccessor.getComponentOfType(IssueIndexManager.class)
@Field final JqlQueryParser jqlQueryParser = ComponentAccessor.getComponent(JqlQueryParser.class)
getIssuesByJQL("project = ABC AND created >= startOfMonth()")
Collection<Issue> getIssuesByJQL(String jql) throws Exception {
    Query query = parseQuery(jql)
    return getIssuesByJQL(query, ComponentAccessor.jiraAuthenticationContext.getLoggedInUser())
Collection<Issue> getIssuesByJQL(Query query, ApplicationUser user) throws Exception {
    if (!indexManager.isIndexAvailable()) {
        return new ArrayList<>();
    if (ThreadLocalSearcherCache.inSearcherContext()) {
        return searchService.search(user, query, PagerFilter.getUnlimitedFilter()).getResults();
    } else {
        return JiraThreadLocalUtils.wrap(
                        searchService.search(user, query, PagerFilter.getUnlimitedFilter()).getResults())
                .call();
Query parseQuery(String jql) throws JqlParseException {
    return jqlQueryParser.parseQuery(jql);
Long Nguyen-Thanh October 6, 2024
Hi @Sergei Troshin ,
    } else {
                .call();
 Thanks for your help! Your code block has given me the solution for my problem!
SERVER
