Hi
I have 2 groups , while creating a issue one group want X custom field while other group doesn't want that custom field.
IN BRIEF:
Lets say , 2 groups be A&B, and two custom fields be X&Y
1.While creating an issue on CREATE ISSUE SCREEN "A "group want "X" custom filed for same issue type (task) and same project, Y field shouldn't be visible
2.And for B group ,While creating an issue on CREATE ISSUE SCREEN they want Y field on same issue type (task) on same project, X field shouldn't be visible.
Hope for the detailed steps.
Thank you.
You would need an add-on for it like Power Scripts (Live Fields) or ScriptRunner(Behaviours)
Hi Matveev,
I'm using cloud version, Please can you provide me the addon and script for that.
It is not possible for Cloud. UI can not be modified in the Cloud version.
You do not need to write a script for the ScriptRunner plugin. You can find an example here:
Help us plant more trees
