Problem with @Inject
lpopek January 30, 2019
I have 3 classes.
One class is annotated as @Component and @Named. In second class I use @Scanned annotation and can inject first class with @Inject below constructor. Example:
FirstClass firstClass;
@Inject
public SecondClass(FirstClass firstClass){
           this.firstClass = firstClass;
Everything works. But… If I try also parallel inject first class to third class as above I had exception
 _[o.a.c.c.C.[.[localhost].[/jira].[action]] Servlet.service() for servlet [action] in context with path [/jira] threw exception [java.lang.NullPointerException] with root cause_
_[INFO] [talledLocalContainer] java.lang.NullPointerException_
I passed this problem through create object of first class in constructor like:
public ThirdClass(FirstClass firstClass){
this.firstClass = new FirstClass();
But… It’s wrong solution. How to fix it with normal adnotation @Inject or something other?
Alexey Matveev
January 30, 2019
You should also put the Scanned annotation to the third class and use Inject in the constructor.
lpopek January 31, 2019
In Third Class I already have @Inject and @Scanned annotations. Third Class dont implement anything and extends.
@Scanned
public class ThirdClass {
@Inject
public ThirdClass(FirstClass firstClass;) {
Problem is resolved. I used Fabric Pattern and in this case is something otherwise. Thanks for help.
