I have problem with Jira Cloud for sheets.
When I click on open, an empty window opens. I can't log in. Where is problem?
Hello @Bartosz Solarski ,
If my understanding is correct you were able to install the Jira Cloud for Google Sheets add-on, but you are not able to connect to Jira by following the steps to connect to Jira from the below documentation page since nothing is displayed when clicking on Open:
Connect your cloud site/instance
Open a Google Sheets spreadsheet and select Add-ons → Jira Cloud for Sheets → Open…
Click CONNECT, this will open a new browser window.
Select the site you want to add from the list of available sites, and click Accept.
Can you kindly confirm this is correct and that you are following the steps from above documentation?
Now, if this is the case, I have just followed the same steps and this is what I see after installing the add-on in Google Sheets, when I click on Open:
If you cannot see what's shown in the above screenshot, can you kindly let us know the following:
If you are following different steps, or trying to do anything different, please let us know and provide as many details as possible.
Finally, I can see you have opened a support request for this issue. In case you get the issue solved in there, please take some time to paste the solution in here as well, so that it can be useful to other community members.
Dario
Resolveu o seu problema com esta solução?
I found solution. Propably port is blocked. Which port communicate add-on?
Hi @Bartosz Solarski ,
The add-on should be using the standard https port (443).
However, I am able to reproduce the reported behavior by installing the add-on and not configuring it at the first time. Then apparently something is left in the browser session that prevents the add-on from correctly displaying the next time:
However, if then I access the same google sheet with the same account from an Incognito window, everything is working fine:
I have tested this in the latest version of Chromium (Version 75.0.3770.90).
Can you kindly try to configure the add-on using an incognito or private window (depending on the used browser) or use a different internet browser and let us know if this works for you as well?
Dario
Welcome to great meetings, with less work. Automatically record, summarize, and share instant recaps of your meetings with Loom AI.
