Need to return true if and only if the following condition is true
the customfield ="CTI Alert" or (the user in group TIER2 and customfield !="CTI Alert")
import com.atlassian.jira.component.ComponentAccessor;
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject("11504");
def value = (String)issue.getCustomFieldValue(customField);
if (value = "CTI Alert") || (value != "CTI Alert") && isUserMemberOfGroup('Tier2')
return true;
else
return false;
What could be the problem and what is the correct syntax?
What is the error? I am not a compiler, but I can see two problems
def customField = ComponentAccessor.getCustomFieldManager().getCustomFieldObject("customfield_11504");
if(( (value = "CTI Alert") || (value != "CTI Alert")) && isUserMemberOfGroup("Tier2"))
import com.atlassian.jira.ComponentManager
import com.atlassian.jira.issue.CustomFieldManager
import com.atlassian.jira.issue.IssueManager
CustomField customField_name = customFieldManager.getCustomFieldObjectByName('Incident Source');
return true;
else
return false;
Currently testing this, seems no errors raised
Try like this:
def customField_name = customFieldManager.getCustomFieldObjectByName('Incident Source');
return true;
else
return false;
