Jira are using as authentication server for Bitbacket. But recently we redirect all traffic to Jira to https. So now users cant authenticate in Bitbacket. Jira base url and server url for Crowd server are the same https://jira.mydomain.com. Application name and password are correct. In Jira white list Bitbacket added. And Bitbacket and Jira have working certificates and accessible by https. But when i testing server setting for connecting to Crowd server i getting error
Connection test failed. Response from the server:
javax.net.ssl.SSLHandshakeException: sun.security.validator.ValidatorException: PKIX path building failed: sun.security.provider.certpath.SunCertPathBuilderException: unable to find valid certification path to requested target
As I understand there are some problem with certificates but I dont get how to fix it...
You need to add Jira’s certificate to the Bitbucket Java Truststore. Basically this but from BB https://confluence.atlassian.com/adminjiraserver075/connecting-to-ssl-services-935391760.html
Added certificate but now i`m getting error
com.atlassian.crowd.exception.InvalidAuthenticationException: Application failed to authenticate
For testing i create a new application in Jira user server, and even turned off white list. But when i creating new user directory in Bitbacket with 100% right name and password i still getting the same error.
But we have apache before jira, i think its all about him... Probably the best idea will be to create a new instance and configure Jira with tomcat without any other proxy
It’s much better using a proxy in front. Changing to using Tomcat to terminte SSL won’t help since the problem was on the consuming end.
If you look at the new error, it’s no longer a Java certificate error, this is Jira rejecting the auth attempt.
Do you see an error in the Jira logs? Try putting 0.0.0.0 /0 for the IP of Confluence in Jira. Are you putting in Jira’s IP into Confluence or the hostname? If it’s the IP is it the IP of Apache or direct to Jira? If it’s the IP try switching to hostname since Apache is likely doing name based routing.
Thanks a lot! You was right with 0.0.0.0 /0 in IP of Jira user server. Its working now.
And i had a Jira hostname in Bitbacket.
But why I shouldn't use tomcat instead of apache? It also can be configured for ssl.
