Processing JIRA issues from commit comments of own git repository
Oleksandr Presich
Hello guys,
could please advise how can I process JIRA issues from commit messages if I'm using own local git repository?
I've found some plugins/workaround, but:
  • one works only for BitBucket/GitHub (JIRA DVCS Connector)
  • another do not have such functionality (Git Version Control Viewer)
  • as I know FishEye have such func, but we do not plan to have FishEye yet
  • it could be made with git-commits, but we'd like to have this functionality from JIRA administration
So, could someone give any advices?
Marlon Aguiar
August 15, 2013
Hello there!
If you're using self installed JIRA you can use a plugin such as the Git Version Control Viewer, but if you are in OnDemand you are restricted on using either Bitbucket or Github or integrating a local Stash or Fisheye install using Application Links.
Hope it helps!
Marlon
Oleksandr Presich
So, as a conclusion we can say that JIRA do not have such functionality out of the box.
Midori
August 18, 2015
It is not clear what you mean by "process". If you want to require issue keys mentioned in the commit messages, then the Commit Policy Plugin does this for you.
See the "Commit message must contain issue keys from a JQL query" condition.
