Profields tab in project always empty
d3bgger
hello
we've just installed profields, configured scheme with fields and assigned to project. (Permissions to all)
In project screen, profields tab is shown always empty! I can edit the fields, and insert values, but when i save the tab is still empty! no field is shown!
in admin mode, in profields tab in project, the table list of fields is shown, but with "none" in view and edit! Why is that? (in field manager the view and edit columns have the "All" value)
also there is no option for required field in scheme configuration. Only delete.
Is there sth wrong with the install in general? Is a restart needed?
This is a very helpfull plugin, but right now is useless because of this!
(jira v5.2)
thanks in advance
d3bgger
i found it! there was a js error that the plugin "teamlead calendar" produces when changing tabs.
i uninstalled this plugin, and now works ok!
carlos.fernandez
February 3, 2014
Ah ok, thank you anyway.
carlos.fernandez
February 2, 2014
Hi Nick,
Could you please send us the js error details, if you still have it, in order to investigate the problem?
We want to discard a problem with global variables or methods.
Regards
d3bgger
TypeError: tabToCompare is null (when changing tabs)
the same error as described here:
https://answers.atlassian.com/questions/256321/error-quickcreateissue-when-custom-project-tabpanel-added?page=1#comment-257255
but it wasn't profields that caused it, as i already mentioned!
thanks
