Has anyone installed the Project Role Tab plugin successfully on JIRA 4.3.4?
I can get it to run in JIRA 4.3.3, but in JIRA 4.3.4 I get a null pointer exception.
Issue was against one of my user accounts. The account was missing the display name causing the null pointer.
We are using version 1.4.1, which is compatible
Which plugin version that you are using? If you are using version 1.4.0, you may need to upgrade the plugin version to be compatible with 4.3.4. You can refer to this compatibility matrix: https://plugins.atlassian.com/plugin/details/38661
