Project URL overflows on summary
Tanner Wortham
July 19, 2012
I'd like to use the Project URL to link to our SharePoint site where we keep all the project documents. However, those links are long, and you'll see they overflow into the other fields. I tried anchoring the links similar to the below, but the project URL field must start with 'http'. does anyone have a solution for this?
<a href="some long link">SharePoint Repository</a>
Tanner Wortham
October 30, 2012
I chose to go with using a link in the description field since it allows HTML.
David at David Simpson Apps
You could perhaps just change the link text with JavaScript after the fact. Paste this into the Announcement Banner in JIRA Admin:
&lt;script&gt;
AJS.toInit(function () {
  AJS.$('#pd-url a').text('Sharepoint Repository');
&lt;/script&gt;
This will mean that All URLs have the same text, but that might be OK for you. I don't know.
Tanner Wortham
July 19, 2012
each project link will be a different URL to a different place in the repository so that's almost a solution.
