I have Jira 5.x and FishEye+Crucible 2.7.15 with one big SVN repository for all projects, each project has own path and Crucible project. Activity stream in each Jira project shows changes for all projects, not only for actual project(Jira activity shows correctly). Can I somehow configure system to show only changes for actual project(path)?
I have the same problem with Jira 6.1.3 and FishEye 3.2.0.
There are three places commits show up:
For all projects except one all are the same and show the most recent activity. For one project stream 1 is okay, stream 2 is out of date and stream 3 shows activity from other projects as well.
We have the exact same problem at our work. We are testing to see if the application links have any effect
Hi Cicik.
You can add a Repository Path on JIRA Project, that way the Source tab will only show information related to the configured Path:
Test that configuration on one single JIRA Project and please let me know if the result is what you are looking for.
Douglas Fabretti
Atlassian Support
Thanks for answer,
but Source tab is OK(I already have that configuration). Activity stream in each Jira project shows changes(from FishEye) for all projects, not only for actual project(Jira activity shows correctly).
Save your spot
