×I resolved this issue myself:
Since I am using Custom user groups (not default jira-* groups), projects created afresh had problem with default Roles. I changed default Roles and all fixed.
https://support.atlassian.com/browse/JSP-179491
Adding in a KB link for feature reference: https://confluence.atlassian.com/display/JIRAKB/JIRA+Project+Disappeared+and+missing+even+the+newly+created+project
Hi Shahriyar,
Do you have permissions to browse the project you're currently creating a Kanban board for?
Is this happening for all boards you try to maken (Both scrum and kanban)?
It seems to be a permission problem, so I would check the permissions of the corresponding projects and your general permissions. More information about JIRA Agile permissions can be found here : https://confluence.atlassian.com/display/AGILE/JIRA+Agile+-+JIRA+Configuration#JIRAAgile-JIRAConfiguration-Permissions
Best regards,
Peter
