Project list - add new custom specific field
Juliane Di Lascio
If I open the project list in JIRA about "View all projects" I can see all projects with pre defined values. (Project / Key / Project Lead / Project Category / URL)
I want to create a new field for a project-relevant information.
I don't want to see this information in the project dependend issues. I only need this information in this list (and if possible in the project detail screen).
I searched already for plugins. So we installed the Metadata plugin, but this does not support our requirement.
What can I do for getting such new field?
If we have to write a plugin for it - does anybody already created a new field and can tell me how to do?
Juliane Di Lascio
This plugin is too expensive for us. So I am searching for another solution.
Nic Brough -Adaptavist-
January 7, 2016
Mmm, I don't think I've seen any competitors for it, but your luck on the marketplace may be better than mine! If you can't then you'll have to judge the cost of writing something similar (probably only worth it if you have more simple requirements and Profields is overkill for what you want)
January 7, 2016
You do need an add-on, as there are no project custom fields.
Before starting any code though, check out the "Project fields" add-on.  https://marketplace.atlassian.com/plugins/com.deiser.jira.profields/server/overview
Help us plant more trees
