Project managing sidebar not showing SLA and some other options
Diego Wilson May 16, 2019
Greetings:
I have a service project in Jira 8.1 and Service Desk 4.1 , but I can't see the SLA menu, edit the Request Type (as describe in the manual , also the screen is diferent) and others option from the project management sidebar like the documentation says;
2.- This is my project.
Before this I used Jira 7.2 and Service Desk 3.2 and never had this problem. Also I have all the permissions as admin.
I hope to be clear.
Thanks.
Diego Wilson May 30, 2019
Hi , anyone have the same issue. The only thing that's try it's reinstall everything
Brant Schroeder
It is most likely a permission issue.  Make sure you have a license for Jira Service Desk associated with your account.  You may also need to add yourself as an agent on that project to get all of the service desk functionality.
Diego Wilson May 17, 2019
Hi Brant:
Thanks for answer, i have all the permissions and my user is a agent for the project but it didint work.
Brant Schroeder
Can you send me a screenshot of the user roles section of the project.
Here is.
Diego Wilson May 20, 2019
Hi , Any idea? I installed the same version of jira in another pc and I can see SLA and edit the request , having the same permissions as I showed before.
Read the story
