Promote changes to a different environment
Séb P.
September 30, 2013
I try to find the best way to promote changes done in our integration environment to the production. Actually, we just replay all our setting manually done in integration to production, which lead to a lot of errors due to missing things...
Is there any way to store/get a list of all new custom fields, workflows, screen, permission schemes, projects, users, etc done since a given point in time?
Even if we cannot replay it automatically into the production, a listing may be enough for us: at least, it will prevent any omissions...
Thanks in advance!
Timothy
September 30, 2013
Séb P.
September 30, 2013
Hum, that seems exactly what I need :) I will give a try!
Thank you :)
VikasB
Plan runners add on adds task to run build plans, test plans, create release, re-deploy , promote deployments or rollback releases as well as REST API
https://marketplace.atlassian.com/plugins/com.mdb.plugins.planrunners/server/overview
Hope this helps.
Register today
