Proxy Error
Mohin Uddin
Hi Expert (atlassian-jira.log) ,
I was unable to access my system at yesterday. When we try to access it appear an error called “Proxy error”.
Could you tell me what caused it?
Have a look screen shot below and let us know the update.
we can access using localhost and when we try to access using base url then appear this error.
I have been checked the attached log file but didn't find any issue.Could you please check this attached log file and tell me what was the reason?
Mohin
Mohin Uddin
Hi Fabio,
How can we resove this issue?
Mohin
Fabio Racobaldo _Herzum_
May 13, 2014
Hi Mohin,
did u try to change language settings as per my link? You should be able to perform this change using localhost.
Let me know,
Fabio
Tiago Comasseto
May 12, 2014
Since it refers to /rest/helptips/1.0/tips, you may also try to disable helptips as in this other KB.
Cheers
May 12, 2014
Hi Mohin,
please take a look here https://confluence.atlassian.com/display/JIRAKB/500+Internal+Server+Error+due+to+ParseException+es-419+is+not+a+valid+language+tag
This is one recurrent error that appears into your log file.
Hope this helps,
Fabio
