Proxy Settings In nginx For ServiceDesk
Robert Reed
Does anyone have a good "recipe" for setting up nginx to proxy or redirect users to use a nicer base URL, IOW to change https://projects.commercialservices.com/servicedesk/customer/portal/3 to something better, like https://helpdesk.commercialservices.com?
I tried the setup below, and while it does work, the user gets redirected by JIRA via a 303 and the URL changes to the long form.
server {
        listen          80;
        server_name     helpdesk.*;
        access_log      off;
        client_max_body_size    10M;
        return 301 https://helpdesk.commercialservices.com$request_uri;
server {
        listen          443 ssl;
        server_name     helpdesk.commercialservices.com;
        access_log      off;
        ssl_certificate         /######;
        ssl_certificate_key     /######;
        location / {
                proxy_pass              http://localhost:8080/servicedesk/customer/portal/3;
                proxy_set_header        Host            $host;
                proxy_set_header        X-Real-IP       $remote_addr;
                proxy_set_header        X-Forwarded-For $proxy_add_x_forwarded_for;
Robert Reed
Tom, I have not. The user-friendly, root URL seemed good enough to get people started on the portal.
Tom Young
February 3, 2016
did you ever find a better solution for this?
Norbert Bede December 26, 2015
hi,
your solution hide original JIRA address and stay on: helpdesk.commercialservices.com.
i can't get it work that way.
thanks. norbert
Robert Reed
The above shouldn't "hide" anything. For example, on my server, I can still reach JIRA via IP and other valid addresses/URLs. The only reason I use nginx is to (try to) present users with a user-friendly URL.
