There is any way to change the status of Epic Link to 'In Progress' automatically if any issue in the epic goes to 'In Progress'?
Thanks in advance
Regards
With the Misc. Worflow Extensions plugin, this is easy. Assuming you use the Server installation and not Cloud:
That's it. Takes about 5 minutes to set up, no code or script required.
Can you let us know if you're on JIRA Cloud or if you're on a self-hosted JIRA installation?
Can you also let us know if you have a scripting add-on like like ScriptRunner or a customization add-on like Misc Workflow Extensions?
