Here's the scenario:
1. I've setup a "Linking issue" custom filed with "query issue come filed" and setup the JQL to fill in the issue in this field. this custom field is named "father_project"
2. I use scriptrunner to set value to this custom field to one issue like this
FatherProjectCustomField.updateValue(null, childTicketIssue, new ModifiedValue(childTicketIssue.getCustomFieldValue(FatherProjectCustomField),FatherProjectIssue.getKey() ), new DefaultIssueChangeHolder())
3. I search issue in JIRA with "father_project = xxx", it return null
4. I open child issue, and check the value in father_project filed, the issue key is correct
5. then I searched issue in JIRA again with "father_project = xxx", it return the child key
it seems that when the code write the value, but JIRA doesn't recognize it until the child issue is open in browser.
It look strange, and I want to find a way to write this custom field value correctly, so that I can get the query result directly in code without opening the child issue on browser UI.
I fixed this issue by using ScriptRunner issue picker instead of query issue custom field
Glad to know that you were able to figure it out and fix the issue. Thanks for sharing @jane chen .
