×Hi,
I have a JIRA.txt file like this.
Issue:
INF-124
INF-742
INF-998
INF-362
How can I get the "Fix Version/s" of those Issues only? I am supposed to create a Bamboo plan which when runs, takes this JIRA.txt as input and gives output as below.
Issue Fix Version
INF-124 PRJ 7.1
INF-742 APP 5.2
INF-998 PRJ 7.1
INF-362 APP 5.2
I havent worked on REST APIs. Could you help me how to do this please?
Hi Theresa!
You can use the GET method of REST on the URL below. Just use any text manipulation function to insert the issue key you need instead of <issue-key>
http://<jira-base-url>/rest/api/2/issue/<issue-key>?fields=fixVersions
Then it will return a JSON-formatted output similar to the one below:
{"expand":"renderedFields,names,schema,transitions,operations,editmeta,changelog","id":"11604","self":"http://localhost:8646/jira646/rest/api/2/issue/11604","key":"AP-13","fields":{"fixVersions":[{"self":"http://localhost:8646/jira646/rest/api/2/version/10101","id":"10101","name":"1.3","archived":false,"released":false}]}}
The name of the version will be returned by the "name"
property (in the example, the version is 1.3) and the issue key will be returned by the "key"
property (in the example, it's AP-13).
Cheers!
Joao
Sweet. That works great. Thank you so much.
