Query to check project specific outgoing mailbox settings
Pranjal Shukla
Some of our projects are configured with separate outgoing mail address than the default address. Wed have huge number of projects and prettty difficult to browse one by one to check the associations. Could any body of you suggest me a query to find it?
Henning Tietgens
March 24, 2013
You can use Script Runner plugin and this script to list all projects and the corresponding from email.
import com.atlassian.core.ofbiz.util.OFBizPropertyUtils
import com.atlassian.jira.project.ProjectKeys
pm = componentManager.projectManager
result = ''
pm.getProjectObjects().each {proj->
    result += proj.key + ": " + OFBizPropertyUtils.getPropertySet(proj.getGenericValue()).getString(ProjectKeys.EMAIL_SENDER) + "\n"
result
If it's null is the default from address.
Henning
