Query to filter the issues for each consecutive weeks
mallikarjunk July 17, 2015
I am filtering the issues which were moved from status test to  client review using :
project = Kt and status changed from  test to client review
we have another requirement to be added to the above , like
is it possible to filter it on weekly bases (for each consecutive weeks) ?
Thiago Zandona
July 17, 2015
Hey Mallikarjun,
Yes, it's possible! If you put "AFTER startOfWeek()" parameter at the end of your query it will do the trick. It will be like this:
project = Kt and status changed from test to client review AFTER startOfWeek()
You can refer to the page below for even more information regarding JQL:
https://confluence.atlassian.com/display/JIRA063/Advanced+Searching
Chris Kast
You can add
AFTER -7d
to get the issues that changed in the last 7 days. So it would be:
project = Kt and status changed from test to client review AFTER -7d
Help us plant more trees
