Querying the Current JIRA Database
Adolfo Casari
November 24, 2016
I am running the query quoted here:
in Script Console, but I get: null
Scriptrunner version is 3.1.4
JIRA 6.4.9
Thanks in advance,
Adolfo Casari
November 24, 2016
Looks that the Script Console only show results if you use return in the code, so instead of:
log.debug sb.toString()
I use
return sb.toString()
to show the results of the query.
Jeff Louwerse
November 24, 2016
Personally I use the built in method to query JIRA's internal tables .  They replacing your connection declaration with this one.  I cant say for sure it will work as it as I use pure java implementation.
import com.atlassian.jira.ofbiz.DefaultOfBizConnectionFactory;
Connection conn = new DefaultOfBizConnectionFactory().getConnection();
Adolfo Casari
November 24, 2016
Thanks. Tried that but I still get null.
Like • Francisco Savignone likes this
