When we add this field into screen. We cannot load that screen when we try to click the transition.
If we remove that field, we can load easily.
We're using JIRA 6.0.6
please help us
Thanks Jannu,
I installed the latest one (1.3.0). It seems that this is loading problem. The loading icon display but nothing happens.
Please help me,
you check the version of Rating Custom Field supported with jira
https://marketplace.atlassian.com/plugins/ru.slie.jira.plugins.customfield/versions
I think you should have minimum version 1.2.3
