Question about average time in status
philippos
We installed the Average Time in Status chart plugin.
Are we correct to assume that this field will collect data for future issues' actions?
Are existing past data blank regarding this field?
If yes, can we fill past data in any way?
philippos
Thanks for your answer.
I mean my JIRA has been in place for 5 years.
I install the chart plug in today.
Will all the issues have values in the "average time in status field"?
Or only issues I update from now on?
Benito Picarelli
March 30, 2015
Hello Philippos,
Yes, the gadget will grab the issues based off of the filter configured in the gadget. It also refreshes based off of the configured interval you put there.
Also, not sure I get what you meant with data blank regarding the field - could you clarify it a bit?
